Unity Connection subscriber mailbox size
Answered Question
Jan 21st, 2010
Hello all,
I am running Unity Connection 7.1.3. How can I tell the size of an individual subscriber's mailbox?
-mike
Correct Answer by Rajesh Revuru about 7 years 3 months ago
From the User Menu, select "Mailbox" and you will find information about the mailbox size and will also tell you about how many messages user has
Overall Rating: 5 (2 ratings)
Correct Answer
Rajesh Revuru Thu, 01/21/2010 - 12:24
  • Silver, 250 points or more
Rob Huffman Thu, 01/21/2010 - 12:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Michael,
Just in case you want to do multiple/or all users in one sweep
Connection User Data Dump (CUDD) Tool
The Connection User Data Dump (CUDD) is a Windows-based remote database administration tool available on the Cisco Unity Tools website. CUDD allows you to export specific information about users to a file that can be viewed or imported into another application, such as a database utility or Microsoft Excel. When the data is exported, the tool automatically creates a header row that lists the data type found in each column of the output, for ease of import into other programs.
The tool is available from the "Superb" Unity Tools site;
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
From the Help Notes;
Requirements/Special Notes
This version of User Data Dump runs on Windows XP/2000/2003 or Vista.
***This version of User Data Dump only works with Unity Connection 7.0(1) or later.
You must enable the ODBC proxy service on the Unity Connection server and attach to the database using an account enabled for the remote database access role. See the next section for details on this.
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm
Hope this helps!
Rob
