How to create a 2nd vlan on a private switch behind a pix asa5510
w951duu
I've got a situation where a client has an ASA5510 Pix with a switch behind the internal interface.  The switch has only vlan 1, but now wants to create a 2nd vlan on the switch for a new server.
How would I accomplish this?  I can't trunk on the interface to the PIX, so how would I get them access to the new vlan.
3 Accepted Solutions
Reza Sharifi
Hi Greg,
You can create a sub-interface on the ASA for each vlan
interface Ethernet0/1.1
vlan 8
nameif int
security-level 100
ip address 172.16.8.1 255.255.255.0
interface Ethernet0/1.2
  vlan 9
nameif int2
security-level 100
ip address 172.16.9.1 255.255.255.0
Reza
w951duu wrote:
I'll have to remove the ip address on the current interface then create a sub for it as well, no?  The client is concerned about down time, but I'm assuming there will be some while I turn on trunking on the switch as well.
Thanks for your help.
Gregory
Yes you can't do this without some downtime for both the ASA and the switch.
Jon
Yes, you would need short outage window to do it
Reza
6 Replies 6
Reza Sharifi
Hi Greg,
vlan 8
nameif int
security-level 100
  vlan 9
nameif int2
security-level 100
Reza
w951duu
Gregory
Jon
Thanks Jon
Reza
Thank you Reza
