Collin Clark Fri, 01/29/2010 - 08:11
  • Purple, 4500 points or more
Nothing. The + means it's a spare part (which means nothing really) and it's exactly the same product as the non + part number.
Hope that helps.
Justin Huffman Tue, 03/09/2010 - 11:20
This is not correct.  = means spare, but this is a port adapter and they'd all be spares unless you bought a BUN, right?
In this case the + means it's the enhanced version.  The PA-T3+ and PA-2T3+ will support Kentrox signaling "dsu mode 1" with subrate timing for fractional T3 service. This is NOT supported on non+  As far as I know that's the only difference; however, the non + unit is EOL.
