ASA5510 unable communication between eth0/1 and eth0/2
Answered Question
Jan 21st, 2010
I have seen some previous posts regarding this matter but the solution is not quite clear.  Here is my issue:
I have a ASA5510 that has the following configuration:
ethernet 0/0 outside security level 0
ethernet 0/1 inside security level 100      (192.168.2.0/24)
ethernet 0/2 private security level 100      (192.168.3.0/24)
same−security−traffic permit inter−interface
access-list nonat extended permit ip 192.168.2.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.3.0 255.255.255.0
nat (Inside) 0 access-list nonat
nat (Inside) 1 0.0.0.0 0.0.0.0
nat (private) 0 access-list nonat
nat (private) 1 0.0.0.0 0.0.0.0
The servers on both were able to access internet. However, they cannot talk to each other. When I ping between 2 sides, the firewall log showed:
portmap translation creation failed for icmp src Inside:192.168.2.151dst private:192.168.3.101(type 8, code 0)
I am not sure what do I miss. Can anyone help?
Thanks in advance
Correct Answer by Kureli Sankar about 7 years 6 months ago
Your access-list appears incorrect.
Pls. change it to the following:
access-list nonat extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list nonat extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
-KS
Overall Rating: 5 (1 ratings)
Correct Answer
Kureli Sankar Thu, 01/21/2010 - 19:49
  • Cisco Employee,
-KS
members1st Fri, 01/22/2010 - 07:09
After change the access-list and it works.
Thank you so much.
vilaxmi Thu, 01/21/2010 - 20:05
  • Cisco Employee,
I see that you are facing assymetric routing issue in your n/w.
Is the default gateway of users behind Private and inside ifc the ASA itself or do you have a layer 3 device like router ? If you have one. then let the router handle the inter subnet communication.
Should you not have any router, then you could try using TCP State Bypass mechanism in ASA (8.2(x) + only).
Please read more about tcp-state-bypass method to overcome assymetric routing issues:
http://cisco.com/en/US/docs/security/asa/asa82/configuration/guide/conns_tcpstatebypass.html
Vijaya
