bypass URL filtering in IOS
Jan 21st, 2010
Hi All,
I am trying to configure 2811 IOS to bypass url filtering from some PCs inside our LAN, but I can't find any command to do it.
any suggestion would be very appreciated
Panos Kampanakis Mon, 01/25/2010 - 14:38
Not sure what your config looks like.
But look the config in
class-map g1-http-class identifies what traffic to match and block. In that class you can use an ACL to tell what pc ip addresses are filtered. So you can deny the ips for the exempted pcs and they will not be filtered.
I hope it helps.
