WakeOnLan (WOL ) through Cisco 870 not working
Jan 21st, 2010
I need to allow WOL packets through a Cisco 870W router to powerup pcs at a remote location. The device is running IOS version 12.4(9)T
The WOL magic packet will be coming from VLAN1 (192.168.2.0/24)  and going to FastEthernet4 (192.168.6.0/24).
The WOL application sends UDP packets on port 9
Here are the relevant running-config sections
interface Vlan1
ip address 192.168.2.30 255.255.255.0
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
interface FastEthernet4
ip address 192.168.6.1 255.255.255.0
** ip helper-address 192.168.2.1
** ip helper-address 192.168.2.10
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no cdp enable
** the iphelper addresses are the domain dhcp servers.
I've also found documents recommending I add
ip forward-protocol udp 9
which I've added and still nothing. Can anyone tell me why this is not working?
Thank you.
Vic.
paolo bevilacqua Fri, 01/22/2010 - 20:40
  • Hall of Fame,
    Founding Member
Try setting a static ARP entry for the PC, on the router
vic.orgos Sun, 01/24/2010 - 15:49
It is not just one PC. I need to be able to wake up any workstation in the subnet on the other side of this router. Adding static arp entries is unmanageable.
Jon Marshall Sun, 01/24/2010 - 16:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no cdp enable
Thank you.
Vic.
Vic
Add this to your config under the vlan 1 interface -
interface vlan 1
ip helper-address 192.168.6.255
Jon
vic.orgos Wed, 01/27/2010 - 15:36
Solved it myself. I found that the PC that sends the magic packet,  which in our case is running RHEL (linux), needs a static route to the network in question. I then added
under FastEthernet 4, which is the interface for the network where the pcs are in.
Once I got that working, I locked it down a bit by creating an ACL
access-list 101 permit udp host 192.168.2.70 192.168.6.0 0.0.0.255 eq discard
and changed the first command to use the ACL like this
ip directed-broadcast 101
That is it. Thanks to all took the time to reply.
Vic.
