01-21-2010 07:49 PM - edited 03-06-2019 09:24 AM
hi experts,
just out of curiousity, i did some speedtest on our ADSL 2 meg line. i tried to speedtest my connection 3x (see attached) but never attain 2meg max and download speed varies everytime. can someone shed some light on this? is speedtest reliable to measure your connection? what other tests are recommended? thanks!
Solved! Go to Solution.
01-25-2010 09:46 PM
hi ganesh,
thank you for your response. i would like to know a good ftp site for testing or do i need to install a 3rd party ftp software. can you refer one?
Hi Jhon,
Check out the below link for downloading a third party ftp software for testing purpose:-
http://core-ftp.software.informer.com/2.1/
hope to help !!
If helpful do rate the valuable post.
Ganesh.H
01-24-2010 02:13 AM
hi experts,
Hi Jhon,
Lots of tools are there to test the bandwidth utilization for link like Bandwidth meter to test the link i would suggests you to perform ftp transaction as ftp is bandwidth greedy protocol this will help you out to identify the amount of bandiwdth used by the link with speed test tool also.
Hope to help
Ganesh.H
01-25-2010 08:43 PM
hi ganesh,
01-25-2010 09:46 PM
hi ganesh,
Hi Jhon,
hope to help !!
Ganesh.H
