56K Serial Com modem
Jan 21st, 2010
Hi, Nowadays, we don't find anymore 56K Serial Com port modem in the market. Most of them are using USB port type. If we were to connect to AUX console port of the router, we will use the Cisco AUX console cable which is RJ4-45 to DB25 then DB25 to DB9 to the modem.
Please advise is there a better solution to this problem.
Steven
Ganesh Hariharan Fri, 01/22/2010 - 00:45
Steven
Check out the below link  hope that clears out your query !!
http://72.163.4.161/en/US/tech/tk801/tk36/technologies_tech_note09186a008009428b.shtml
If helpful do rate the valuable post.
Ganesh.H
