Seed File
Jan 21st, 2010
I have an query, I am trying to add about 1000 windows XP hosts onto cisco mars using seed file. From seed file instruction as per cisco mars I have filled all things in seed file, but where can I fill the interface IP setting in seed file.
Since I dont want to use pull method, I dont want to provide any username or password for that.
I had filled in this columns in Seed File :
Column A : windows host name
Column E : WINDOWS
Column F : RPC
Column U : Access IP Address
On importing this into cs-mars, I get an error message "Status: 5 line(s) in the file 'X.csv' have errors. Some of them may have been partially imported. Rest of the error-free lines are successfully imported. Please view backend log for detailed information."
On checking if the device was successfully imported, I find the all details being filled with receive checkbox checked by default but the under the tab "Enter interface information" there is no details filled.
Want to check if incase any windows machine have more than one interface IP how do I add using seed file.
Thank you.
Archana.
