Dynamic Cookie Learning on the CSM
Jan 21st, 2010
Hi Guys,
I'm looking to configure dynamic cookie learning on the CSM such that the CSM learns the value of the Cookie set by the server.  I wanted to know how this is configured - i'm assuming it is done as follows, for a case where the server sets the Cookie name as JSESSIONID:
sticky 100 cookie JSESSIONID timeout 30
Is this correct?
thanks
Sheldon
Sean Merrow Fri, 01/29/2010 - 07:25
Hi Sheldon,
You are correct, however, in your example configuration, the entire cookie value would need to remain static.  Most times with JSESSIONID, I see customer's specifying where to look for the static portion of the cookie.  For example, when servers return the JSESSIONID, part of the cookie will always be the same for the specific server, but the rest of it will change.
  cookie offset 0 length 8
 vserver VSERVER
  virtual 10.10.10.1 tcp WWW
  sticky 5 group 100
  serverfarm REAL_SERVERS
  persistent rebalance
  inservice
The above example shows how to do it if you want to do sticky on the first 8 characters of the JSESSIONID cookie value.  Another common set of values is:
cookie offset 53 length 10
Hope this helps.
Sean
