Duplex Mismatch between Cisco 2960 (LANBase Image) and Cisco 6506 Switch
Jan 22nd, 2010
I have the following issue;
I am getting a duplex mismatch between a Cisco 2960 TT-L Switch running IOS 12.2(35) LAN Base Image (Gig0/1) and a Cisco 6506 Switch running IOS 12.2(33)SXH Adv IP Services (Gig2/19).
I have tried several combinations of the duplex/speed settings on both sides but the only that works is setting duplex/speed AUTO on the Cisco 2960 which ends up autonegotiating to HALF duplex and 100Mbps.
What cou;d be the issue? IOS bugs?
Overall Rating: 5 (1 ratings)
edwardwaithaka Fri, 01/22/2010 - 01:38
I have upgraded the Cisco 2960 Switch to version 12.2(52). The interfaces are now at FULL duplex but cannot negotiate to 1000Mbps.
zvondovec Fri, 01/22/2010 - 04:42
Can you put here results of sh run int ... commands?
edwardwaithaka Fri, 01/22/2010 - 04:57
Ports are on default;
int gig0/1
switchport mode access
switchport access vlan zzz
duplex auto
speed auto
int gig2/18
no switchport
ip address x.x.x.x y.y.y.y
no speed
no duplex
zvondovec Fri, 01/22/2010 - 05:36
Is there only cable between those 2 boxes, or is there some convertor (fiber optic)?
Also you can try speed nonegotiate command on both sides.
Leo Laohoo Fri, 01/22/2010 - 21:35
On both, try the following interface command "speed auto 1000".
glen.grant Sat, 01/23/2010 - 04:56
  It is generally advised you use auto on both sides for gigabit. If they are not negotiating gig then I would take a serious look at the cabling . Unlike fastether which takes 2 pairs you must have 8 good wires in the entire path between the 2 devices  in order to negotiate gig as gig uses all 8 wires to achieve gig speeds . Even 1 bad wire out of the 8  it will not negotiate gig .  Make sure speed negotation is actually turned on for the 6500. you can check this with the following counterintuitive  command
no speed nonegotiate .  Verify with the command
show interfaces GigabitEthernet slot/port transceiver properties
Good info for explaining the different states for gig port settings.  http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/intrface.html#wp1020621
jimenez.reuben Thu, 06/28/2012 - 15:20
On the 2960 switch the "dual purpose" uplinks need to be manually configured with "media-type" to be able to set speed/duplex. Default would not allow setting these 2 attributes.
interface GigabitEthernet0/1
switchport mode trunk
media-type rj45
speed 100
duplex full
GigabitEthernet0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is
Description: Uplink to Cat01
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
Related Content
