ICM/IPCC database writing method
Jan 22nd, 2010
Does anyone know what is the method Cisco ICM/IPCC uses to write data to a database?. My Cisco db is on SQL server and I would like to know if it uses dts packages or any application specific technique.
Thank you in advance
Edward Umansky Mon, 01/25/2010 - 08:20
The application itself handles writing data to the database and synchronizing, it does not use DTS packages or SQL jobs.
romualdgrosse Tue, 01/26/2010 - 05:01
I don't know the way to write anything in an external database directly from ICM nodes : Could you tell us more on the way you do it ?
Personnaly, I use an external CVP application developped using Call Studio and the "database" element ...
Romuald Grosse.
david.macias Tue, 01/26/2010 - 07:00
You can only do simple reads from within the ICM script.  You could build an app gateway to accomplish what you want, but I suggest you
stick to doing it through CVP as it's the recommended way, you can have better error handling, and peripherals are made for these kind of tasks.
david
