upgrade stack 3750
Jan 22nd, 2010
I have to upgrade a stack (2 menber ,3750 24ts)
with ios advipsevices , but the ios present is ipservices.
DO i have to upgrade separately each menber ,
because of different types of ios(incompatibility)
or do i upgrade only the master ?
vvasisth Fri, 01/22/2010 - 05:52
ok when it comes to stack upgrade all switches in the stack needs to be on the same IOS or else stack will be broken.
there is a very easy way to upgrade the stack in one go. Make sure you use a ".tar" IOS this is the one with GUI feature in it. Once you have the IOS downloaded on you computer foloow the below given doc to perform an IOS upgrade as there is a diff way to upgrade with .tar file and TRUST ME its the easieast way to do that :-
Hope this helps.
