Blocker and TLS
Answered Question
Jan 22nd, 2010
Hello @all,
I configured the Blocker for TLS and it accepts incoming TLS connections. But the delivery to the local mail server is not TLS encrypted. What do I have to set to enable TLS encryption for the delivery to the local mail server?
The local mail server accepts TLS connections. So I guess I missed something on the blocker.
Correct Answer by jasbryan about 6 years 12 months ago
In response to your question, you would log into the blocker. Under the (Network tab) you will click on SMTP authentication . Go ahead and give it a name and select a profile type and click next, then fill out those fields and click finish,submit the changes and then commit the changes ! This should create a TLS connetion to your mail server. Hope this helps.
Jason
Overall Rating: 5 (1 ratings)
Correct Answer
jasbryan Fri, 01/22/2010 - 05:15
Jason
