3750 ME
Jan 22nd, 2010
Hello!
I have 3750 ME and i configured
logging trap debugging
logging host 213.xx.xx.60 vrf INAT
logging 192.168.133.221
logging 192.168.133.208
and now i want ro remove line "logging host 213.xx.xx.60 vrf INAT"
ME3750-6#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ME3750-6(config)#no logging host 213.xx.xx.60 vrf INAT
% Ambiguous command:  "no logging host 213.xx.xx.60 vrf INAT"
ME3750-6(config)#
and i try
Host 213.xx.xx.60 not found for logging
ME3750-6(config)#
how can i remove this line?
Thank you!
Leo Laohoo Fri, 01/22/2010 - 21:33
Try this ...
1.  Save the current config and copy the config.text to your desktop using the command "copy flash:config.text tftp://";
2.  Use Wordpad (do NOT use Notepad) and open this file;
3.  Scroll down and edit or remove the offending IP address and save the file;
4.  Copy the file back to the appliance using the command "copy tftp:///config.text flash:running-config".
If you are satisfied, then save the config.
Please rate if my post is applicable or helpful.
ruslanbelov Mon, 01/25/2010 - 01:03
Hello!
I try it. And i change my startup config.
sh startup
Then i do
copy startup-config running-config
sh run
Nothing change!
Ganesh Hariharan Mon, 01/25/2010 - 02:59
Hello!
sh startup
Then i do
sh run
Nothing change!
Hi Belov,
As per the error  % Ambiguous command: which means that commands are not enter enough characters for the command to be recognized.
Try the following :
Reenter the command followed by a space and a question mark (?). The keywords that you are allowed to enter for the command appear.
Hope to help
Ganesh.H
ruslanbelov Mon, 01/25/2010 - 04:53
Hi!
ME3750-6(config)#no logging host 213.xx.xx.60 vrf INAT ?
% Ambiguous command:  "no logging host 213.xx.xx.60 vrf INAT "
That's all.
Ganesh Hariharan Mon, 01/25/2010 - 08:39
Hi!
That's all.
Hi Belov,
To delete the configuration of the syslog server host from the VRF, use the no logging host command with the vrf vrf-name keyword and argument.
Same has been told in below link also
http://www.cisco.biz/en/US/docs/ios/12_2sr/12_2sra/feature/guide/srvrfslg.pdf
Try one thing also no logging competely first then check the command is exists or not and what is the version of ME3750-6
Hope to help
Ganesh.H
Ganesh Hariharan Sat, 01/23/2010 - 21:35
Hello!
ME3750-6#conf t
ME3750-6(config)#
and i try
ME3750-6(config)#
Thank you!
Hi Belov,
The procedure for removing the no logging host is the same which you are trying it should delete the host configuration,check out the below link which tells the same hope to help.
http://www.cisco.biz/en/US/docs/ios/12_2sr/12_2sra/feature/guide/srvrfslg.html#wp1081985
and if that doesn't help try what leo has suggested.
Ganesh.H
