TACACS+ Configuration
rkoudmani
I am trying to build a tacacs+ config to roll out on my network devices.  I have an ACS doing the authentication.  What I would like to do is have the ACS authenticate my users and their enable access.  However I would like to leave console access using both the local username and the local enable password in order that I have a backdoor in case of future issues.  I have all this working except the ability to go into enable mode from console using the local enable password.  I get an auth error as I think teh device is trying to ACS auth the enable password due to this :
aaa authentication enable default group tacacs+ enable
I can get around it by applying a privlive level 15 to line to come straight into enable mode but it seems less secure.
Any ideas?
Here are the relevent bits of my config (and I do have a local username and enable defined)
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login console local
aaa authorization exec default group tacacs+ local none
aaa authorization exec console local
aaa authorization commands 0 default group tacacs+ local none
aaa authorization commands 1 default group tacacs+ local none
aaa authorization commands 15 default group tacacs+ local none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
line con 0
password 7 <xxx>
login authentication console
Thanks in advance
Jagdeep Gambhir
Level 10
Level 10
Hi Rasheed,
Unfortunately, there is no way to apply a specific method list for the enable authentication to apply to the console.
Named method list for enable authentication is not supported.
~JG
Do rate helpful posts
Jagdeep Gambhir
Level 10
Level 10
Hi Rasheed,
~JG
Thanks for the quick response.
