Transport Performance Optimization Modules
Jan 22nd, 2010
Did anybody worked maybe on AIM-TPO-2 modules? I'm having a little problem with configuration. I made simple configuration in the lab and made little test but unfortunatelly it seems that there is no compressin in between - test traffic is pute ftp.
What I'm not 100% sure is 'sctp-peer peer' what IP address should be used as peer in each module?
As explanation I've PC connected to Gi0/0 interface on Router A with 192.168.41.11 IP and I'm trying to transfer some files over FTP to Server (169.16.0.11) connected to Gi0/0 interface on Router B. I tried to transfer some bigger pdfs but never saw any increase in speed
Configuraiton from both routers attached below:
--- Router A ---
version 12.4
boot-start-marker
boot system flash c2800nm-ipbasek9-mz.124-24.T2.bin
boot-end-marker
interface Loopback0
ip address 128.10.0.1 255.255.255.0
interface GigabitEthernet0/0
ip address 192.168.41.241 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex full
speed 100
interface GigabitEthernet0/1
ip address 172.16.10.1 255.255.255.0
duplex full
speed 10
transport-opt 1 interface Transport-Opt-Service-Engine0/0
description *** Compression Module ***
ip unnumbered Loopback0
service-module ip address 128.10.0.10 255.255.255.0
service-module ip default-gateway 128.10.0.1
hold-queue 60 out
ip route 128.10.0.10 255.255.255.255 Transport-Opt-Service-Engine0/0
ip route 169.16.0.0 255.255.255.0 GigabitEthernet0/1
end
Router A Module
tpo id 1
default policy-action  compress-sctp
bandwidth-profile high-speed-sctp
sctp-peer 172.16.0.10 tos 0
sctp-peer 172.16.0.10 tos 1
sctp-peer 172.16.0.10 tos 2
sctp-peer 172.16.0.10 tos 3
sctp-peer 172.16.0.10 tos 4
sctp-peer 172.16.0.10 tos 5
sctp-peer 172.16.0.10 tos 6
sctp-peer 172.16.0.10 tos 7
exit
--- Router B ---
version 12.4
boot-start-marker
boot system flash c2800nm-ipbase-mz.124-24.T2.bin
boot-end-marker
interface Loopback0
ip address 128.20.0.1 255.255.255.0
ip address 169.16.0.1 255.255.255.0
duplex auto
speed auto
ip address 172.16.10.10 255.255.255.0
duplex full
speed 10
service-module ip address 128.20.0.10 255.255.255.0
service-module ip default-gateway 128.20.0.1
hold-queue 60 out
ip route 128.20.0.10 255.255.255.255 Transport-Opt-Service-Engine0/0
ip route 192.168.41.156 255.255.255.255 GigabitEthernet0/1
end
Router B Module
tpo id 1
sctp-peer 172.16.0.1 tos 0
sctp-peer 172.16.0.1 tos 1
sctp-peer 172.16.0.1 tos 2
sctp-peer 172.16.0.1 tos 3
sctp-peer 172.16.0.1 tos 4
sctp-peer 172.16.0.1 tos 5
sctp-peer 172.16.0.1 tos 6
sctp-peer 172.16.0.1 tos 7
exit
Thanks in advance,
Bart
