Is inrush current limiting bad for 3kW supply in 7613 chassis?
Jan 22nd, 2010
This inquiry may be in the wrong forum location. If so please direct me to the appropriate location.
We manufacture power conversion equipment for locations where utility power is not available. Our customer wants a power supply for a Catalyst 6500 series switch in a 7613 frame. The 7613 frame is equipped with two 3kW load-sharing power supplies (Cisco part: WS-CAC-3000W). The key power requirements for these power supplies is: 16A at 220Vac.
Our power supply can deliver up to 30A at 220Vac. During tests at power up, we notice that the inrush currents exceed the 30A limit of our power supply and consequently, the 220Vac is severely distorted. This distortion only lasts about 10 cycles and the 220Vac is restored gradually. After 2 seconds, all the DC outputs of the Cisco power supply are available, and the frame begins power up.
Question: Is the limitation on the inrush current detrimental to the power supplies?
