Unified presence
Answered Question
Jan 22nd, 2010
Hallo,
I have the callmanager set-up,presence also set up well and am having my licenced users.
I keep getting the error message -No line appearances currently exists on the Cisco Unified Communications Manager.
How do i go around this-or how should these line appearences be configured?
Nick.
Correct Answer by Rob Huffman about 7 years 3 months ago
Hi Nick,
Just to try and fill in for Michael and jonathan for a moment (+5 points
each guys!)
You will see the steps as outlined in the good reference docs. Then you should be good to go
https://supportforums.cisco.com/docs/DOC-1112;jsessionid=0958FBC44DCBCA0879822014F42FB536.node0#Associate_User_with_Line
http://pushkarbhatkoti.wordpress.com/2009/06/08/cisco-presence-integration-with-ccm-7x-in-20-minutes/
Cheers!
Rob
Correct Answer by htluo about 7 years 4 months ago
You go to CUCM Admin > Device > Phone.  Click on the phone.  Click on the DN on the left hand side.  Go to the bottom of the page.  Click "Associate to End User".
Michael
http://htluo.blogspot.com
Correct Answer by Jonathan Schulenberg about 7 years 4 months ago
You need to associate a user to each line appearance. You can do this manually or through BAT.
If you view a directory number appearance on a specific device, you will see a User Association section at the very bottom of the page. You need to associate the end user account with the appearance.
Overall Rating: 5 (5 ratings)
Correct Answer
Jonathan Schulenberg Fri, 01/22/2010 - 08:18
  • Cisco Designated VIP,
    2017 IP Telephony
Correct Answer
htluo Fri, 01/22/2010 - 08:24
  • Red, 2250 points or more
Michael
Koiser_Nicholas Sun, 01/24/2010 - 09:34
Thank you good peeple,
Am a bit new to unified presence.After associating the end user to the directory number all should be well for with line appearence on presence?or is there anything else i need to do?
Nick.
Correct Answer
Rob Huffman Sun, 01/24/2010 - 10:04
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Nick,
each guys!)
Cheers!
Rob
Koiser_Nicholas Mon, 01/25/2010 - 02:29
Thank for your contribution,your guide really helped.
Thanks one again.
