IMAP from WAN
Marcos Hernandez Fri, 01/22/2010 - 09:58
  • Blue, 1500 points or more
My advice is that you setup a VPN for these users, if no more than 10 (simultaneous).
Marcos
Marcos Hernandez Fri, 01/22/2010 - 10:09
OK, then you can forward the IMAP (TCP 143) port to the CUE IP (10.1.10.1), using CCA. Notice this is NOT a secure connection. You can change it in CUE to use SSL and forward the IMAP port for that.
The UC500 will have to have a static public IP on its WAN interface, or you will need DDNS.
Marcos
