01-22-2010 10:26 AM - edited 03-06-2019 09:25 AM
Hi All,
I would like to know the SSH version 2 key length on my 2821 router like 768, 1024 or 2048. Is there a show command or other command to do the job? I tried "show ssh" and "show ip ssh" but won't help.
Any input will be appreciated.
01-22-2010 04:02 PM
I don't know any command that will tell you that . You can look at the key itself but it does not tell you what length the key is .
01-22-2010 09:35 PM
Hi All,
Hi Robert,
As suggested it is not possible to check the key length but genral speaking about the modulus lenghth is When you generate RSA keys, you will be prompted to enter a modulus length. The longer the modulus, the stronger the security. However a longer modules takes longer to generate (see Table 12 for sample times) and takes longer to use.
Cisco IOS software does not support a modulus greater than 4096 bits. A length of less than 512 bits is normally not recommended. In certain situations, the shorter modulus may not function properly with IKE, so we recommend using a minimum modulus of 1024 bits.
Note As of Cisco IOS Release 12.4(11)T, peer public RSA key modulus values up to 4096 bits are automatically supported.
The largest private RSA key modulus is 2048 bits. Therefore, the largest RSA private key a router may generate or import is 2048 bits.
The recommended modulus for a CA is 2048 bits; the recommended modulus for a client is 1024 bits.
Sample Times by Modulus Length to Generate RSA Keys
Router 360 bits 512 bits 1024 bits 2048 bits (maximum)
Cisco 2500 11 seconds 20 seconds 4 minutes, 38 seconds more than 1 hour
Cisco 4700 less than 1 second 1 second 4 seconds 50 seconds
Hope to help
Ganesh.H
10-25-2017 10:56 PM
We cannot find from show commands in cisco switches. But if you login through putty, right click on putty icon of the device, select even logs. Go down, it will show the RSA key value used, whether 1024 or 2048.
06-18-2020 02:05 PM
"show ip ssh" shows the modulus of the local key in output as below.
SSH Enabled - version 2.0 Authentication methods:publickey,keyboard-interactive,password Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr MAC Algorithms:hmac-sha1,hmac-sha1-96 KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1 Authentication timeout: 120 secs; Authentication retries: 3 Minimum expected Diffie Hellman key size : 2048 bits IOS Keys in SECSH format(ssh-rsa, base64 encoded): HTTPS_SS_CERT_KEYPAIR Modulus Size : 768 bits ssh-rsa XXXXX
