Unity Connection 7.X Message size
Does anyone know how I can get calculate the storage space needed for messages left in Unity and CUC for a particular codec?   If using G711, can I simply multiply the length of the message in seconds by 80K?  Or would it be by 64K?   Or ????
Glenn
Jaime Valencia
Table 3-1     Comparison of Audio Codecs Used for Recording
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/design/guide/7xcucdg025.html#wp1069840
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
That helps.
Thanks!
Glenn
