how to see Pre-shared key in VPN concentrator 3000
Jan 23rd, 2010
Hi, I have one Cisco VPN Concentrator 3000. I forget Pre-Shared key for many tunnells which I have configured on this device.
Please help how to see configured Pre-Shared key?
james.bastnagel Sat, 01/23/2010 - 06:02
Rupesh,
If I recall correctly on the concentrators, you can view the txt config and
see the keys in plain text or if you browse to the IKE proposals in the web
interface, you should be able to view the keys there as well-- Configuration
| System | Tunneling Protocols | IPSec LAN-to-LAN option and select your
IPsec configuration.
If they arent in clear text anymore as I recall, then the keys will have to
be changed on each end and documented.
James
On Sat, Jan 23, 2010 at 1:29 AM, rupesh_kashyap <
