IOS Upgrade
Jan 23rd, 2010
Hello
Upgrade of IOS failed with error (Not enough space on device), deleting an IOS and uploading new IOS is correct
copy tftp : flash :
Address or name of remote host []? 192.168.1.1
Source filename []? c2800nm.bin
Destination filename [c2800nm.bin]?
Peter Paluch Sat, 01/23/2010 - 08:43
  • Cisco Employee,
Tom,
Your question is not very clear but if you are asking whether it is OK to delete the old IOS from the FLASH and download a new one, then yes - this is OK. I would still recommend backing up the old IOS just in case you will need to revert back.
Best regards,
Peter
glen.grant Sat, 01/23/2010 - 08:41
  • Purple, 4500 points or more
     Not sure of the question here .  It's as simple as checking to see if there is enough space in flash for your new image, do a "dir flash: " . Is the reported free space bigger than the image size you are trying to put on ? If no then you will have to delete at least 1 image to make room for the new image.Then issue "copy tftp flash: "  , it will ask you your address of the tftpserver , input , it will then ask you the name of the image  just copy and paste the name of the image in there and hit enter a couple of times and it should go if there is enough space in flash which verified with the "dir flash:  command.   The image name you posted is not a valid imagename , check the imagename and try to download the valid imagename again.
Leo Laohoo Sat, 01/23/2010 - 14:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Why don't you just get a new CF?  Make sure it's <2Gb and format the CF before you put any IOS into it.
