Topology Services
Answered Question
Jan 23rd, 2010
When i click on the link attributes in Network Topology lan edge view it give me the error attached .
Correct Answer by Joe Clarke about 7 years 4 months ago
Yes, I mean HUM.  Since you do not have it installed, you will not be able to use that cross-launch option.
Overall Rating: 5 (1 ratings)
Joe Clarke Sat, 01/23/2010 - 10:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do you have the Health and Utilization Monitor add-on installed?  If not, then this cross-launch option will not work.
lambay2000 Sat, 01/23/2010 - 21:21
Hey Calrke,
Do u mean to say HUM module ?? if so then my LMS is not extended only basic,with RME,IPM,DFM,CM,CS,CWA,CV.LMS Portal.
Correct Answer
Joe Clarke Sun, 01/24/2010 - 10:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
