Fun with NAT on ASA
Jan 23rd, 2010
If  a host on 192.168.1.x, the inside interface tries to ping a host on 192.168.10.x (a network behind a router which is connected 6.1)
The ASA returns:
Jan 23 2010 10:17:58: %ASA-3-305006: portmap translation creation failed for icmp src inside: dst inside: (type 8, code 0)
and the ping fails.
If you try to ping directly from the ASA you get a similar result:
Sending 5, 100-byte ICMP Echos to, timeout is 2 seconds:
Jan 23 2010 10:20:35: %ASA-4-313004: Denied ICMP type=0, from laddr on interface inside to no matching session
Seems to me this should work right out of the box, suggestions?
<config snip>
name Cowacella description named after thomas J's Monticello with a cow twist
access-list inside_access_in_1 extended permit ip any any
global (outside) 1 interface
nat (inside) 1
access-group inside_access_in_1 in interface inside
route inside Cowacella 1
spollock Sat, 01/23/2010 - 10:25
I failed to mention, I have "same-security-traffic permit intra-interface" enabled as well.
vilaxmi Sat, 01/23/2010 - 21:06
You are running into assymetric routing scenario over here.
Either you can set the default gateway of hosts on all subnets to be the 6.1 (router) & have its default gateway set to the ASA inside ifc OR if you real,ly wanna keep the ASA as everybody's default gateway, then you can use the tcp-state-bypass feature introduced in 8.2 release of code for ASA, so that assymetric situation here can be handled correctly by ASA.
Check it out at the release notes :
vilaxmi Sun, 01/24/2010 - 09:09
Making the firewall inside ifc proxy arp for inside hosts using global (inside) 1 ifc statement along with the Identity static translation for destination
command was a workaround we used PRE 8.2 era.. Anyways, I would  suggest the usage of solution  (tcp-state-bypass feature) in the 8.2 + codes.
Related Content
