Cannot copy .lic into Ds-9124-k9 bootflash for license installation.
Jan 23rd, 2010
Dear sir,
      Please advise below why i can ping but can't copy the .lic file into bootflash of ds-9124-k9 .  Currently the 9124 have existing running 8 which have default running license. I wish to add on additional .lic for extra ports. Please advise.
Thanks and appreciation.
Switch1# copy tftp: bootflash:
Enter source filename: 5359062MDS20100114213236121.lic
Enter hostname for the tftp server: 137.55.67.80
Trying to connect to tftp server......
Connection to server Established. Copying Started.....
TFTP get operation failed:Read-only file system
Switch1# copy ftp: bootflash:
Enter hostname for the ftp server: 137.55.67.80
Enter username: anonymous
Password:
local: /bootflash/5359062MDS20100114213236121.lic: Read-only file system
penang-FSW1# ping 137.55.67.80
PING 137.55.67.80 (137.55.67.80) 56(84) bytes of data.
64 bytes from 137.55.67.80: icmp_seq=1 ttl=128 time=0.245 ms
64 bytes from 137.55.67.80: icmp_seq=2 ttl=128 time=0.242 ms
64 bytes from 137.55.67.80: icmp_seq=3 ttl=128 time=0.205 ms
64 bytes from 137.55.67.80: icmp_seq=4 ttl=128 time=0.185 ms
64 bytes from 137.55.67.80: icmp_seq=5 ttl=128 time=0.236 ms
--- 137.55.67.80 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 3997ms
rtt min/avg/max/mdev = 0.185/0.222/0.245/0.028 ms
Switch1# sh port-license
Available port activation licenses are 0
  Interface   Cookie    Port Activation License
  fc1/1       16777216        acquired
  fc1/2       16781312        acquired
  fc1/3       16785408        acquired
  fc1/4       16789504        acquired
  fc1/5       16793600        acquired
  fc1/6       16797696        acquired
  fc1/7       16801792        acquired
  fc1/8       16805888        acquired
  fc1/9       16809984        eligible
  fc1/10      16814080        eligible
  fc1/11      16818176        eligible
  fc1/12      16822272        eligible
  fc1/13      16826368        eligible
  fc1/14      16830464        eligible
  fc1/15      16834560        eligible
  fc1/16      16838656        eligible
  fc1/17      16842752        eligible
  fc1/18      16846848        eligible
  fc1/19      16850944        eligible
  fc1/20      16855040        eligible
  fc1/21      16859136        eligible
  fc1/22      16863232        eligible
  fc1/23      16867328        eligible
  fc1/24      16871424        eligible
Switch1# dir
      12288     Oct 12 09:35:48 2009  lost+found/
   18678784     Oct 12 09:37:17 2009  m9100-s2ek9-kickstart-mz.4.1.3a.bin
   51055100     Oct 12 09:39:04 2009  m9100-s2ek9-mz.4.1.3a.bin
       1209     Jan 14 20:05:06 2010  mts.log
Usage for bootflash://
   82652160 bytes used
   80319488 bytes free
  162971648 bytes total
Switch1# sh license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
PORT_ACTIVATION_PKG           No    8   In use never       -
10G_PORT_ACTIVATION_PKG       No    0   Unused             -
Switch1# sh license host
License hostid: VDH=FOX1331GTHS
Guanlin Zhang Mon, 02/01/2010 - 21:56
  • Cisco Employee,
Here are the steps I would recommend to narrow down problem
step 1 and 2 are to see if problem is ftp related
1) use following command to verify you can copy file from MDS to ftp server
copy bootflash: ftp:
2) verify you can copy file from ftp server to you local PC
3) "copy run  bootflash:test_run.cfg" and then "show log last 5" to check if there is error message.
or you can do "dir bootflash: | include test_run.cfg" to verify if file is created.
If step 3 was not able to create the file, something wrong with flash. please open TAC service request to further verification.
Or If the system has not been in production yet, you can back up startup configuration, running configuration and license files etc... to ftp/tftp servers. And then reload the switch to see if the flash problem goes away.
Trending Topics: Storage Networking
