Connection drops on a SA520W
Jan 23rd, 2010
I have the SA520W installed, firmware 1.1.21.
In some way when i enable my SITE-TO-SITE VPN's i get connection drops via NAT. (so not on the VPN hosts)
for example i have 2 site-to-site vpn's active, and i'm connected to a external (not inside the vpn cloud) host via RDP the connection drops every 10 seconds and comes back again in also a few seconds.
When i disable al site-to-site vpn's the external connections are fine.
Somebody has equel problems?
Is there a way to get support on my problem, and how?
Jan van den Dungen
jvandendungen Sat, 01/23/2010 - 16:13
It also happens when for example copy 3GB trough wireless, another pc lost all connection to external rdp's
jvandendungen Mon, 01/25/2010 - 10:21
Hello Steven,
That's great that you like this problem ! :)
Can i send you the config file by mail? i cannot publish it to the world.
Jan
