ACL's and ACEs
Bruce Summers
Is it possible to remove an ACE that is encompassed by an ACL?
exp:  access-list vlan1000 line 1 extended permit ip object-group X object-group Y
object-group network X
  network-object 10.10.10.0 255.255.255.0
object-group network Y
network-object 192.168.1.0 255.255.255.0
in the scenario above, I have 30 IP's in use in the 10.10.10.0, spread across the class C (ie. 10.10.10.10, 10.10.10.30, 10.10.10.70, 10.10.10.135 etc...)
I want to keep the /24 intact, but i would like to remove those IP's in that class C that arent being used...
I know, it sounds silly, but what i've ran into, is over the course of time, some of my object-groups/acl combinations have grown so large, that i'm against the max allowable ACE's in my context (running multi context mode on FWSM 3.2.2)
I dont see a way around this problem, with the exception of reducing the number of partitions (did that already, currently at 6 acl partitions and each have virtual contexts created in them) OR removing some of the 0 hitcnt ACE's...
any ideas would be greatly appreciated...
Bruce
Jon Marshall
Bruce
Bruce
Not sure what you mean. Your example -
only amounts to one ace because you have defined network objects rather than individual host entries.
I think i may have misunderstood the question.
Jon
6 Replies 6
Jon Marshall
Bruce
Bruce
Jon
you understood correctly...
maybe I misunderstand ACE's vs ACL's...
but, now that i read your post, i think it became clear...i thought that an ACE was a "subunit" of an ACL..i guess not :-)
so, because of the use of the object groups, What i want to do is not possible i dont think...
bruce
bruce
Bruce
ACL is the access-list as a whole
ACE is a single entry in the access-list
So for example if you had done this -
object-group network hostsx
network-object host 10.10.10.1
network-object host 10.10.10.2
etc..
network-object host 10.10.10.254
and then
access-list vlan1000 line 1 extended permit ip object-group hostsx object-group Y
then that would expand into 254 individual ACEs one for each host ie.
access-list vlan1000 permit ip host 10.10.10.1 object-group Y
access-list vlan1000 permit ip host 10.10.10.2 object-group Y
etc...
so in that case if only 10 hosts were actually being used then it would be worth removing the entries not in use from the object-group. But because you have used a network ie. 10.10.10.0 255.255.255.0 that doesn't expand into 254 entries, it is simply one entry ie. ACE so you don't get any benefit.
Jon
understood, and figured that was the case...
looks like i'm backed into a corner with this then...
thanks for the reply...
Bruce
I have another question concerning the ACL's.
with using the the subnets in the ACE rather than individual IP's within the subnet, should I see hit counts on the ACE's?
exp:  object-group network X
        network-object 10.10.10.10.0 255.255.255.0
        network object 192.168.1.0 255.255.255.0
sho access-list vlan1000
access-list vlan1000 line 70 extended permit ip 10.10.10.0 255.255.255.0 192.168.1.0 255.255.255.0 (hitcnt=0) 0x6935d70
the outputs of the show access-list shows a zero hitcnt for every subnet ACE within my context...
So, my deduction is that even though there is a hit between, for example, 10.10.10.30 and 192.168.1.100, the output will always show a 0 hitcnt on the ACE...
is that a safe deduction?
bruce
bruce
Bruce
You should see hitcounts on an ACE whether that ACE is using object-groups or not. Are you sure the traffic is not being allowed by another ACE in your acl that is before this one ?
Jon
