Offramp Gateway to place a call(VXML)
I recently configured Offramp Gateway to place a call and activate a VXML script when the called party answers. I use the Cisco NetWorks ESMTP server to trigger a call using the following settings:
EHLO CMUC01.com
mail From: "Grant" <[email protected]>
rcpt To: [email protected]
data
Trigger
Each time I leave the mail from settings blank or enter a invalid phonenumber, the call goes out with our main telephonenumber. Totally normal.If I use the phonenumber currently configured, the call goes out as 76572xxxx and is also displayed on the called phone.
Now my question is, is there a way to block the caller id when a person is called using this trigger?
Thanks in advance,
~Grant
Wes Schochet Mon, 01/25/2010 - 14:01
What vxml tag / command are you using to initiate the outdial?  There are parameters that can be set to modify the ani digits.  Look for "cisco-aniexpr"
