Gateway and Trunk
Jan 24th, 2010
I need to know when I should configure gateway and when I shoul configure Trunk?
Overall Rating: 3 (1 ratings)
Marwan ALshawi Sun, 01/24/2010 - 01:25
" The basic function of a gateway is to translate between different types of networks. In the data environment, a gateway might translate between a Frame Relay network and an Ethernet network, for example. In a VoIP environment, voice gateways are the interface between a VoIP network and the public switched telephone network (PSTN), a private branch exchange (PBX), or analog devices such as fax machines"  source " Cisco Voice Gateways and Gatekeepers"
while the trunk is a logical link used for sending or terminating a voice call
for example you can have a SIP trunk that terminate on a voice gateway
or you may have a voice gateway define as h323 that connect to PSTN using for example ISDN
and you have an other PSTN link through a sip trunk direct from the callmanger to the Teleco using SIP trunk between the CCM and the Telco
these only simple possable scenarios to show the differences between a trunk and a gateway
if helpful Rate
JustForVoice_2 Sun, 01/24/2010 - 11:28
Actually the main reason of my question related to presence server
In presence server I shoud define the CCM as Presence Gateway and on the CCM I should create SIP Trunk
Adrian Saavedra Sun, 01/24/2010 - 14:06
And also you have to define CUPS as an Application Server in CUCM. This is done in System->Application Server.
Hope this helps.
-- Adrián.
JustForVoice_2 Mon, 01/25/2010 - 04:09
I know that I did Presence many times.
What I mean why we use gateway in Presence and Trunk in CCM
