7206 VXR - WCCP High CPU
Jan 24th, 2010
7206 VXR NPG-2 - When i enable WCCP, CPU shoot up from 20% to 70%.
Can anyone please let me know which IOS version should i use so CPU utilization not goes high.
I configure basic configuration.
Thanks in Advance
Yasir Ashfaque Sun, 01/24/2010 - 06:52
are you terminating PPPoE on the Router ??
beside that you wil have to enable wccp and then type the same command, and tell me the output.
There could be 2 reasons for high cpu utilization, either a bug or cef could be disabled on the input interface, but it will clear the things when you will enable wccp v2 and check the cpu usage.
