Quick one on Link aggregation
Jan 24th, 2010
Ive got a situation where I have a router with a gigabit ethernet interface and a fast ethernet interface.
I want this router to be a router-on-a-stick so there is a trunk coming from a switch to the gig interface, the rest of my network has good redundancy and this link is kind of a SINGLE POINT OF FAILURE so I was wondering if I can aggregate FA and the GI int on a 2800 using LACP or Etherchannel (or anyhow) its not directly for the extra bandwidth its more for fault tolerence.
Thank you in advance everyone
Dan
Ganesh Hariharan Sun, 01/24/2010 - 05:31
Dan
Hi Dan,
Check out the below link for your requirement and with detail configuration commands hope it help out your query !!
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst5000/hybrid/routing.html#wp41701
If helpful do rate the valauble post.
Ganesh.H
glen.grant Sun, 01/24/2010 - 05:36
  No you cannot etherchannel unequal speed links into a etherchannel.  If you want to do this  you would have to drop the gig link to 100 meg and try it .  It's not something I have tried on a router though .
Ganesh Hariharan Sun, 01/24/2010 - 05:51
Thanks Glen for clarification for unequal speed for etherchannel configuration.
Ganesh.H
