Internet browsing through RA VPN
Jan 24th, 2010
Hi All
    I want to configure Remote access VPN for users on ASA and once VPN is established these users should browse the internet from the HQ(server side) and not through the local internet at client side(as in the case of split-tunnel).Is this type of configuration possible?
Anvar
james.bastnagel Sun, 01/24/2010 - 09:21
Yes.
In the case of a site to site tunnel, in your network lists/ACL's for the
tunnel you would have at the remote site something like:
access-list VPN extended permit ip (remote site local network addresses)
0.0.0.0 0.0.0.0
Then the opposite at your HQ location. This will force all traffic through
the vpn from that remote site.
In the case of RA vpn's using the IPSEC or SSL client, simply do not define
a list of networks in the configuration and it should, by default, tunnel
all traffic. There is some additional information on this and similar common
vpn issues at the link below.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807...
On Sun, Jan 24, 2010 at 8:15 AM, anva12345 <
