Cisco question pattern for 640-802
Jan 24th, 2010
Can anyone tell me that doe the simulation type questions still exist in CCNA exam or not?  I have heard that all questions are itn objective type & no simulation quetion will be there. Is that right?
Pease give me a brief on latest pattern of CCNA 640-802
Ganesh Hariharan Sun, 01/24/2010 - 22:24
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi Subrata,
Check out the exam pattern for CCNA 640-802
Exam Pattern: The pattern may vary from exam to exam, depending on how many questions are there to be answered. The question types found on the CCNA exam are:
    * Multiple Choice with Single answer: Student is required to select a single answer from a range of options (generally 4-5) by clicking on a radio button.
    * Multiple Choice with Multiple answer: Student is required to select a range of options. The number of options to select is specified. The selection is made by clicking on a checkbox. A “v” appears against selected checkboxes.
    * Drag And Drop: These questions are graphical in nature. Student is required to drag options to different drop areas.
    * Fill in the Blank: Student is required to type in the missing text to complete the sentence.
    * Router Simulation: Router simulation questions test knowledge of Cisco IOS in simulated environment. All of Cisco IOS commands are not supported by the simulator, however the task can be performed with the available commands in the simulator. Do note that the exam engine may be slow when switching between the simulator-based questions and the standard multiple-choice questions.
Hope to help !!
If helpful do rate the valauble post.
Ganesh.H
