Outbound CLI
Answered Question
Jan 24th, 2010
I have a UC500 with an ISDN BRI trunk.
I have an issue with outbound Caller id.
All calls display the CLI of the b channel not the DDI range.
Here is an extract of the config
Last configuration change at 03:50:30 GMT Wed Jan 13 2010 by jroche
! NVRAM config last updated at 13:19:50 GMT Mon Jan 18 2010
version 12.4
isdn switch-type basic-net3
trunk group  ALL_BRI
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class custom-cptone CCAleavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice register global
max-dn 88
max-pool 22
voice translation-rule 4
rule 1 /0180/ /180/
rule 2 /0181/ /181/
rule 3 /0182/ /182/
rule 4 /0183/ /183/
rule 5 /0184/ /184/
rule 6 /0185/ /185/
rule 7 /0186/ /186/
rule 8 /0187/ /187/
rule 9 /0188/ /188/
rule 10 /0189/ /189/
voice translation-rule 5
rule 1 /0190/ /190/
rule 2 /0191/ /191/
rule 3 /0192/ /192/
rule 4 /0193/ /193/
rule 5 /0194/ /194/
rule 6 /0195/ /195/
rule 7 /0196/ /196/
rule 8 /0197/ /197/
rule 9 /0198/ /198/
rule 10 /0199/ /199/
voice translation-rule 6
rule 1 /182/ /6490190/
rule 15 /.*/ /6490190/
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
rule 1 /6490186/ /186/
voice translation-rule 2222
voice translation-profile AA_Profile
translate called 2001
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile Eircom_Called_4
translate called 4
voice translation-profile Eircom_Called_5
translate called 5
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_BRI
translate calling 6
voice-card 0
dspfarm
dsp services dspfarm
interface BRI0/1/0
no ip address
no ip unreachables
no ip proxy-arp
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
trunk-group ALL_BRI 64
interface BRI0/1/1
no ip address
no ip unreachables
no ip proxy-arp
Correct Answer by Steven Smith about 6 years 12 months ago
There is a bug with CCA 2.2.1 and caller ID for PRI and BRI.  The following should fix your problem.
config t
trunk group ALL_BRI
translation-profile outgoing PROFILE_ALL_BRI
Let me know if that works for you.
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Smith Mon, 01/25/2010 - 09:23
config t
trunk group ALL_BRI
