Setup SR520 VPN - help needed asap
Jan 24th, 2010
Need help ASAP.
Does anyone know how to create a site-to-site VPN using a Cisco SR520 router?
I cannot use the Cisco Config utility as it will not connect to the router.  I must use the commands.
It is a PreShared key Authentication method, IKE encryption scheme, AES-256. Let me know what else you need.
