RAS Server allowing multiple clients in and telnet redirection to correct reciever.
Jan 24th, 2010
Product being used:
IOS (tm) 3700 Software (C3725-ADVIPSERVICESK9-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
cisco 3725 (R7000) processor (revision 0.1) with 118784K/12288K bytes of memory.
R7000 CPU at 240MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
MICA-6DM Firmware: CP ver 2940 - 7/24/2002, SP ver 2940 - 7/24/2002.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
24 Serial network interface(s)
24 terminal line(s)
1 Channelized T1/PRI port(s)
In combination with a server running:
tac_plus version F4.0.3.alpha.v9 (Extended Tac_plus)
• The goal is create a RAS Server to allow multiple clients to call in and separate them via DNIS.
Then specify an auto-command to send the traffic to the correct receiver of that call.
We are not stuck on doing this with tacacs if there is a more efficient way of doing this.
The thought was to only send the authorization to tacacs to allow for the dnis map to point the traffic to the correct receiver.
aaa authentication login DIALIN none
aaa authorization exec DIALIN none
If we set aaa authentication login DIALIN none it works without any issues but does not go to the tacacs server and therefore does not allow us to use the dnis map commands.
aaa authentication login DIALIN group AAA-mydial
If we set aaa authentication login DIALIN group AAA-mydial using the aaa group server tacacs+ AAA-mydial it goes out to the tacacs server as expected but then it requires a login ID at least in order to get into a session.
aaa authorization exec DIALIN group AAA-mydial
When we change the aaa authorization exec DIALIN group AAA-mydial it fails and does not even send the information out to the tacacs server.
aaa authentication login DIALIN “see above for options “
aaa authorization exec DIALIN “see above for options”
aaa new-model
aaa group server tacacs+ AAA-2035554677
server 172.16.0.109
aaa group server tacacs+ AAA-2035554570
server 172.16.0.109
aaa group server tacacs+ AAA-2035554571
server 172.16.0.109
server 172.16.0.109
aaa accounting exec default start-stop group AAA-2035554570
aaa dnis map enable
aaa dnis map 2035554677 authorization network group AAA-2035554677
aaa dnis map 2035554677 accounting network start-stop group AAA-2035554677
aaa dnis map 2035554570 authentication login group AAA-2035554570
aaa dnis map 2035554570 authorization network group AAA-2035554570
aaa dnis map 2035554570 accounting network start-stop group AAA-203554570
aaa dnis map 2035554571 authorization network group AAA-2035554571
aaa dnis map 2035554571 accounting network start-stop group AAA-2035554571
aaa session-id common
ip subnet-zero
ip cef
line con 0
line 65 88
no motd-banner
no exec-banner
privilege level 15
no vacant-message
login authentication DIALIN
modem Dialin
transport preferred none
transport output telnet
escape-character NONE
telnet transparent
line aux 0
line vty 0
exec-timeout 0 0
password cisco
line vty 1
exec-timeout 0 0
transport preferred telnet
transport input all
Cisco_Kid-jesgenes Fri, 02/12/2010 - 13:45
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
NOTHING LIKE ANSWERING YOUR OWN POST:::
--Well after looking around I found the following on a forum which seems to have gotten us to our destination but uses local authentication to direct the DNIS numbers to the correct receiving system.  Just need to give things a final polishing to make the configuration as clean as possible.
hostname Router
boot-start-marker
boot-end-marker
logging buffered 65536 debugging
enable password cisco
clock timezone EDT -5
clock summer-time EDT recurring
aaa new-model
aaa user profile TEST
server 172.16.0.109
!!!!!  Below defines the AAA-mydial group you are sending the accounting information to.
aaa group server radius AAA-myradius
server 172.16.0.109 auth-port 1645 acct-port 1646
!!!!!  Below you are using the DNISTEST local group for authentication and authorization.
aaa authentication banner ^C^C
aaa authentication login DNISTEST local
aaa authorization exec DNISTEST local
aaa accounting update newinfo
aaa accounting connection DNISTEST start-stop group tacacs+ group AAA-mydial
ip subnet-zero
ip cef
ip audit po max-events 100
isdn switch-type primary-ni
isdn voice-call-failure 0
isdn logging
!!!!!  Below you are directing which DNIS number goes to which receiving host.
username cisco-kid password 0 cisco
username DNIS##1212 nopassword dnis
username DNIS##1212 autocommand telnet 172.16.0.5 22 /stream /quiet
username DNIS##4677 nopassword dnis
username DNIS##4677 autocommand telnet 172.16.0.6 22 /stream /quiet
username DNIS##4570 nopassword dnis
username DNIS##4570 autocommand telnet 172.16.0.7 22 /stream /quiet
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 172.16.0.35 255.255.255.0
speed auto
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice modem
no cdp enable
interface Group-Async0
no ip address
encapsulation slip
dialer in-band
dialer-group 1
async mode interactive
group-range 65 88
interface Dialer0
no ip address
dialer in-band
dialer idle-timeout 3600
dialer-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.254
no ip http server
no ip http secure-server
ip tacacs source-interface FastEthernet0/0
dialer-list 1 protocol ip permit
!!!!!  Below you are further defining the tacacs server and the encryption key to be used.
tacacs-server host 172.16.0.109 key cisco
no tacacs-server directed-request
radius-server host 172.16.0.109 auth-port 1645 acct-port 1646 key ras-secret123
line con 0
!!!!!  Below you are directing all calls to go to DNISTEST for authentication, authorization, & accounting.
!!!!!  Then we are stripping all prompting so that the connection is completely clean.
!!!!!  The only issue was that the aaa banner was still there which is why there is a
!!!!!  “aaa authentication  banner ^C^C” above in the aaa section.
line 65 88
no motd-banner
no exec-banner
privilege level 15
no vacant-message
login authentication DNISTEST
modem Dialin
telnet transparent
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
transport input all
transport output all
telnet transparent
end
tacacs+ config just needs to have an accounting log file defined and all output will be logged there:
Here is my tac_plus.cfg file:
key = "cisco"
accounting file = /var/log/tac_plus-f404.log
-----------------------  the info below this line is irrelevant  ---------------------------
---  Just from me trying to use tacacs for the authentication & authroization----
user = default {
        login = nopassword
        service = exec {
               autocmd = "telnet 172.16.0.5 22 /stream /quiet"
user = Router {
        login = nopassword
        member = dialup
group = dialup {
        default service = permit
        expires = "Apr 1 2010"
        service = exec {
                idletime = 15
        cmd = disconnect {
                permit .*
user = test {
        name = "Dial"
        login = nopassword
        member = dialup
Related Content
