is power Injector included in AIR-BR1410A-E-K9 ?
Jan 24th, 2010
please if there is any body out there, please help me out for the following questions :
1. is power Injector included in AIR-BR1410A-E-K9 default configuration ?
2. is power supply included in AIR-BR1410A-E-K9 default configuration ?
3. is  integrated antenna included in AIR-BR1410A-E-K9 default configuration ?
many thax,
hanish
tcording Sat, 01/30/2010 - 04:01
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Hi Hanish
From memory everything needed is included with the bridge including the power injector, power supply and mounting bracket (unlike the 1300 series)
And the AIR-BR1410A-E-K9 includes integrated antenna (Captured Linear Polarization; 22.5 dBi gain4: 10° E-plane by 12° H-plane beamwidth)
And according to the documentation: https://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5279/ps5285/product_data_sheet09186a008018495c.html
Ease of Use
Based upon IEEE 802.11a technology and utilizing the same Cisco IOS Software as in a wired network, the Cisco Aironet 1400 Series provides a user with a familiar experience that supports an "out-of-the-box" deployment. Convenient LEDs and an externally accessible Received Signal Strength Indicator (RSSI) for alignment feedback/diagnostics and a quick-hang mounting bracket allows for an easy installation process.
To simplify ordering and installation, the Cisco Aironet 1400 Series Wireless Bridge provides the professional or IT installer with all of the components and accessories necessary to complete most deployments, including:
• The Cisco Aironet Power Injector LR for supplying power to the bridge without expensive electrician costs (Figure 5). The power injector also extends the distance the 1400 Series Wireless Bridge can be installed from the network. (Figure 6)
• The Cisco Aironet 1400 Series Multifunction Mount, with its innovative design, to provide greater ease of installation and flexibility. The mount comes complete with stainless steel hardware to improve corrosion resistance.
• Two lengths of shielded Dual RG-6 cables and a building entry point grounding block, all with F-Type connectors for use with the Power Injector LR and connection to the bridge unit.
• A power supply and cord, enough coaxial sealant for all outdoor connectors, and corrosion-proof gel to protect grounding connections.
Troy
Related Content
