AAA Migration
Answered Question
Jan 24th, 2010
I have AAA 4.1 on win 2003. I want to migrate it to 4.2. What should be my migration path ? The update files I have are ACS-4.2.1.15. When I try to upgrade it pops the message that I can upgrade to 4.2.1.15 only from 4.2. Please suggest what migration path should I follow?
Sheeraz
Correct Answer by Jatin Katyal about 7 years 3 months ago
Hi Sheeraz,
I think you are in a process of upgrading your ACS windows from 4.1.1 to 4.2.1.
ACS version 4.2.1.15 version can only be upgraded over ACS 4.2.0.124 since you are running ACS version 4.1.1 so you need to upgrade first to 4.2.0.124 and then to 4.2.1.15
If you are looking regular version of 4.2.0.124 then you need to open up a TAC case but for evaluation version you may download from below listed link:
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-eval
JK
Plz rate helpful posts-
Overall Rating: 5 (1 ratings)
Correct Answer
Jatin Katyal Mon, 01/25/2010 - 04:44
  • Cisco Employee,
Hi Sheeraz,
JK
