Firmware Upgrade Checklist
Jan 24th, 2010
Hello IT guru's
Currently are planning to upgrade our IronPort c350 v5.5.1-011 - to the latest version .. we have two appliance Active-Active .. would you kindly let me know what is the best pratictis in performing the upgrade, would anyone tell me what are the precautions i need to take ? is there any standard checklist ?
Since i am new to IronPort - appricaiate for your open assistnace :-)
pvdberg00 Sun, 01/24/2010 - 23:52
There is an upgrade path in the release notes documentation.
The best is to do one machine first and if everything is oke do the other.
Peter.
msalhauddin8 Mon, 01/25/2010 - 00:08
Thanks for your response..
Would you kindly send me some glipmse or resource ?
pvdberg00 Mon, 01/25/2010 - 00:12
I do not know exactly what you need but here are the steps from the release notes:
Step 1 Save the XML configuration file off the IronPort appliance.
Step 2 If you are using the Safelist/Blocklist feature, export the Safelist/Blocklist database off the IronPort appliance.
Step 3 Suspend all listeners.
Step 4 Wait for the queue to empty.
Step 5 From the System Administration tab, select the System Upgrade page.
Step 6 Click the Available Upgrades button. The page refreshes with a list of available AsyncOS upgrade versions.
Step 7 Click the Begin Upgrade button and your upgrade will begin. Answer the questions as they appear.
Step 8 When the upgrade is complete, click the Reboot Now button to reboot your IronPort appliance.
Step 9 Resume all listeners.
Peter.
msalhauddin8 Mon, 01/25/2010 - 00:18
Great..
Would you kindly illustratre more on Step:4 .. how can i check in the GUI ?
Finally I checked on internet that the best approuch doing the upgrade is thorugh CLI rather than GUI - since in CLI it gives you the status of the proceeding where as in GUI it doesnt-- what's your recommendation :-)
through CLI the cmd is "upgrade"
pvdberg00 Mon, 01/25/2010 - 00:24
I think the GUI is also displaying some status info !
On the System Overview page you can see the System status and the number of messages in Work Queue.
Keep in mind that maybe you have to do some more upgrades on one machine (it is not always possible to go direct to the wanted version)
Peter.
