Problem EtherChannel beetween 7201 and Catalyst 2960
Jan 25th, 2010
I have cisco 7201 (Version 12.4.20T)  with on-board  4 GigabitEthernet interfaces:
      GigabitEthernet 0/0 and GigabitEthernet 0/1 bundled in one logical link  PortChannel 1 and connected to Сisco 3750;
      GigabitEthernet 0/2 and GigabitEthernet 0/3 bundled in one logical link  PortChannel 2 and connected to Сisco 2960;
PortChannel 1 is  working  fine, but PortChannel 2 is working strange.
If I make show interface GI 0/2 adn GI 0/3 , then showed :
show int gi 0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is MV64460 Internal MAC, address is 0021.d8d7.e119 (bia 0021.d8d7.e119)
  Description: Uplink to Macomnet; need check phisical port!
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 24/255, rxload 6/255
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is autonegotiation, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 2d04h, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2d04h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 25557000 bits/sec, 29869 packets/sec
  5 minute output rate 96161000 bits/sec, 15569 packets/sec
     682020535 packets input, 1311889074 bytes, 0 no buffer
     Received 6 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 389 multicast, 0 pause input
     403292412 packets output, 4195595996 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
show int gi 0/3
GigabitEthernet0/3 is up, line protocol is up
  Hardware is i82546, address is 0021.d8d7.e119 (bia 0021.d8d7.e117)
     reliability 255/255, txload 23/255, rxload 1/255
  Keepalive not set
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 90664000 bits/sec, 15042 packets/sec
     11563 packets input, 1305950 bytes, 0 no buffer
     Received 21 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 17 multicast, 0 pause input
     396608924 packets output, 3667016890 bytes, 0 underruns
It's show that in Interface Gi 0/3 Input rate is 0 input packet.
If I shutdown Gi 0/2, then communication is lost and not connectivity.
And If I shutdown Gi 0/3 then communication is fine and having connectivity.
Have anybody had same problem?
Giuseppe Larosa Tue, 01/26/2010 - 04:41
Hello V.rrail197,
your configuration is rather peculiar on a router like C7201 interfaces are usually used as stand alone routed interfaces.
Having created two port-channels each made of 2 GE ports can be part of the problem.
What happens if first bundle is shut or its configuration is removed?
The C3750 is multilayer capable so it may the right choice for intervlan routing without doing it on the C7201.
Hope to help
Giuseppe
v.rrail197 Tue, 01/26/2010 - 06:15
Hi !
I was shut first bundle, It does't happen something.
I need to configure second bundle in the router, Cisco 3750 is  used another role in the network.
Do  you have any ideas?
