Duplicate Devices in LMS 3.0.1
Answered Question
Jan 25th, 2010
Hello clark,
In device Management on common services I'm getting duplicate devices.the same no of devices are seen twice with the management IP (loopback IP address).what could be the possible reason.
Till yesterday it was fine i dont what gone wrong?
Correct Answer by Joe Clarke about 6 years 11 months ago
You need to delete the duplicates from DCR first.  That is, go through DCR, and remove those duplicate entries which you do not want.  Then, run a new Discovery, and see if the deleted duplicates come back.
Overall Rating: 5 (1 ratings)
lambay2000 Mon, 01/25/2010 - 20:48
hello clarke,
when i run the command i get the below error I'm doing according to readme file.
D:\>cd progra~1\cscopx\bin\perl CSCtb16166-0.pl
The system cannot find the path specified.
thanks clarke
Joe Clarke Mon, 01/25/2010 - 21:13
Assuming you are in the directory where the patch lies (which you should be).  Run:
D:\progra~1\cscopx\bin\perl CSCtb16166-0.pl
lambay2000 Mon, 01/25/2010 - 21:27
Hello clarke,
Assuming you are in the directory where the patch lies??
I have kept the folder in D: and am running the command from cmd prompt
i have tried the below before Still i get the below error: Actually i not familar with windows command prompt can u send me the exact step to excecute the command.
D:\> progra~1\cscopx\bin\perl CSCtb16166-0.pl
Can't open perl script "CSCtb16166-0.pl": No such file or directory
i m running the command from start>run>cmd>D:\> progra~1\cscopx\bin\perl CSCtb16166-0.pl
lambay2000 Mon, 01/25/2010 - 21:55
Hello clarke,
The file is  excecuted thanks i was doing mistake after entering the folder i was not specifying the D:/ ,i was directly typing progra~1\cscopx\bin\perl CSCtb16166-0.pl
thanks,
Joe Clarke Mon, 01/25/2010 - 21:56
Go Start > Run, and type in cmd.  Launch the command prompt, then change directory to the directory which contains the CSCtb16166-0.pl script.  Then run:
D:\progra~1\cscopx\bin\perl.exe CSCtb16166-0.pl
lambay2000 Mon, 01/25/2010 - 22:13
Hello clarke,
Still i can see duplicate devices  after running discovery, i see the IP address of the same device with the hostname.
Correct Answer
Joe Clarke Tue, 01/26/2010 - 09:28
