Cisco CSS 11503
rustamovea
I have a problem with configuring Content Rule on Cisco Content Services Switch.
I am configuring Redundancy for NTP, but it doesn't work correct.
Here is the config:
service NTP-Redundancy01
  ip address 10.0.139.17
  active
service NTP-Redundancy02
  ip address 10.0.139.18
  active
owner NTP
  content NTP-RED
    add service NTP-Redundancy01
    add service NTP-Redundancy02
    vip address 10.0.139.119
    port 123
    protocol udp
    active
group NTP-RED
  add destination service NTP-Redundancy01
  add destination service NTP-Redundancy02
  active
What is wrong with this config?
14 Replies 14
rustamovea
This is the output of show flows command:
Src Address     SPort Dst Address     DPort NAT Dst Address Prt InPort  OutPort
10.0.139.18     123   10.0.139.119    123   10.0.139.17     UDP  1/1-139   1/1-139
10.0.153.153    123   10.0.139.119    123   10.0.139.18     UDP  1/1-139   1/1-139
Pleeease Help !
10.0.153.153 - client
10.0.139.119 - VIP address
10.0.139.17 - NTP Server
10.0.139.18 - NTP Server
I created ACL and removed services from the group, but it still doesn't work corret.
  clause 5 permit udp any eq 123 destination any eq 123
  clause 6 permit udp any destination any sourcegroup NTP-RED
could you explain your setup?
- Bridged mode (client-side and server-side VLAN is same IP Subnet but different VLAN ID)
- One-arm mode (only 1 VLAN which contains VIP and servers)?
can you copy your config?
Dario
I have two NTP servers (10.0.139.17 and 10.0.139.18) and many clients. I use CSS to load balance and share requests between two NTP servers. Clients send ntp requests (source port 123, destination port 123) to the configured VIP (10.0.139.119), but don't get replies back.
Everything is OK, then ntp request come from unprivileged port (>1024)
CSS11503# sh run
!Generated on 02/02/2010 02:47:47
!Active version: sg0810106
configure
!*************************** GLOBAL ***************************
  no restrict web-mgmt
  bridge priority 0
  ip redundancy master
  acl enable
  app
  app session 172.7.6.2
  ip management route 10.0.100.0 255.255.255.0 10.0.95.254
  ip route 0.0.0.0 0.0.0.0 10.0.139.254 1
!************************* INTERFACE *************************
interface  1/1
  trunk
  description " *** Trunk to 4000 *** "
  vlan 139
interface  2/1
  bridge vlan 2
  description " *** CSS Redundancy VRRP Heartbeat *** "
!************************** CIRCUIT **************************
circuit VLAN1
  redundancy
circuit VLAN139
  redundancy
  ip address 10.0.139.200 255.255.255.0
circuit VLAN2
  ip address 172.7.6.1 255.255.255.0
    redundancy-protocol
!************************** SERVICE **************************
  keepalive type none
  active
  keepalive type none
  active
!*************************** OWNER ***************************
owner NTP
  content NTP-RED
    active
!*************************** GROUP ***************************
group NTP-RED
  active
!**************************** ACL ****************************
acl 6
  clause 10 permit any any destination 10.0.139.119
  apply circuit-(VLAN139)
acl 10
  clause 10 permit any any destination any
  apply circuit-(VLAN1)
  apply circuit-(VLAN2)
The problem is that yoru group does nat the request and by default the CSS also modifies the src port.
Under the group, you can try "portmap disable" to prevent the src port translation.
See if it helps.
Gilles.
"portmap disable" didn't help.
If it helps, debug on CSS shows:
FEB  2 03:25:23 2/1 5606 FLOWMGR-4: UDP in 10.0.153.153:123->10.0.139.119:123
FEB  2 03:25:23 2/1 5607 FLOWMGR-4: UDP out 10.0.153.153:123->10.0.139.17:123
You are not source NATting.
Reconfigure your source group and add your services as destination service.
I added destination service before, the same result.
group NTP-RED
  active
Can you post the flows again when the destination services are active.
Then destination services are active:
10.0.153.153    123   10.0.139.119    123   10.0.139.17     UDP
10.0.139.17     123   10.0.139.119    123   10.0.139.18     UDP
It doesn't do source port mapping for ports less than 1024.
OK, I see the problem.
You use your VIP address to Source NAT (NO PAT!)
This means that the reply from your server is send back to the CSS to the NATted address (which is also the VIP), and the same port (123), which in its turn is load-balanced again.
Try using a different address for the source NAT then your VIP address.
HTH,
Dario
rustamovea
I made a change to 10.0.139.222   No reply.
group NTP-RED
  vip address 10.0.139.222
  active
CSS11503# sh flows
But it works fine then the source is greater than 1024.
10.0.153.153    39146 10.0.139.119    123   10.0.139.18     UDP
10.0.139.18     123   10.0.139.119    5985  10.0.153.153    UDP
