Mobility
Jan 25th, 2010
Is there a way to get calls received direct to mobile to be transfered to desk phone?
also I have a number of users with iphones. If I install the mobile communicator client on them, is there a way to move from wifi to GSM
thanks
Jonathan Schulenberg Mon, 01/25/2010 - 07:55
  • Cisco Designated VIP,
    2017 IP Telephony
This is called Unified Mobility and will work if the caller originally called the on-net user directory number. User Mobility, specifically Mobile Connect within UC Manager will anchor the call at the enterprise gateway and ring the off-net number simultaneously with the user's on-net IP phone. This allows the user to move the call between the two devices as needed.
Cisco UCM Features and Services Guide - Unified Mobility
Mobile Communicator does not use WiFi at all. It uses the cellular data network to perform auxiliary signaling and features in addition to cellular-based voice traffic. If you have 802.11 and GSM dual-mode handsets, you will need to look at a different product to provide seamless roaming. This is rather expensive however as it requires a location-enabled WLAN, location tracking services through the Cisco MSE, the third-party gateway, and a shim on the mobile handset. Agito Networks is the primary vendor of this technology at the moment.
Jonathan Schulenberg Mon, 01/25/2010 - 11:42
    2017 IP Telephony
Call Routing > Mobility Configuration is part of Mobile Voice Access (MVA). This is also part of Unified Mobility and is covered in the Features and Services document I linked previously.
A dual-mode phone has multiple definitions. Most GSM phones (and CDMA for that matter) are dual- or tri-mode in the cellular frequencies they support. Dual-mode in the cellular industry means a very different thing than dual-mode in the IT industry. I try to always specify 802.11/cellular dual-mode for clarity. For the purposes of roaming between cellular/802.11 frequencies, the list is very specific as it requires a shim on the handset to work. You cannot say that any 802.11/cellular dual-mode phone will work. The iPhone is probably the most glaring example of this at the moment due to the closed platform.
