The incoming call hits the NAT'd IP of the Pub, unfortunately the cluster does not recognize that IP and rejects the call. Is there any way I can make this work? Thanks.
01/22/2010 11:43:06.923 CCM|//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 1037 from 208..x.x.x:[5060]:
INVITE sip:6024667xxx;npdi=yes@12.X.X.X (My Nat'd IP):5060 SIP/2.0
Via: SIP/2.0/UDP 208.x.x.x:5060;branch=z9hG4bK07B7a045e321f57a5a2
To: <sip:6024667xxx@12.X.X.X>
Call-ID: 101124970_1197@208.x.x.x
Looks like I am getting the Invite message. But as you can see the call is coming in to 6024667xxx@12.X.X.X, this is the NAT'd IP of the Pub.
01/22/2010 11:43:06.934 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 208.x.x.x:[5060]:
SIP/2.0 100 Trying
As we are unware of ip.addr 12.X.X.X, we send a NOT found.
01/22/2010 11:43:06.936 CCM|Digit Analysis: Host Address=12.X.X.X DOES NOT MATCH any address for this cluster.|<CLID::StandAloneCluster><NID::10.23.X.X><CT::1,100,185,1.94><IP::208.x.x.x><DEV::><LVL::Arbitrary><MASK::0800>
01/22/2010 11:43:06.942 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 208.x.x.x:[5060]:
SIP/2.0 404 Not Found
Reason: Q.850;cause=1
Date: Fri, 22 Jan 2010 16:43:06 GMT
Allow-Events: presence
Content-Length: 0
To: <sip:6024667xxx@12.X.X.X>;tag=1bf2e1f4-b033-4236-a158-4348f90067ba-22034938
Call-ID: 101124970_1197@208.x.x.xVia: SIP/2.0/UDP 208.x.x.x:5060;branch=z9hG4bK07B7a045e321f57a5a2
CSeq: 3780 INVITE
