Scenario Help
Hi All ,
               I have a common vlan between my both ASA via my core switch for stateful failover .
ASA inside interface
IP address 192.168.10.1 255.255.255.0 standby 192.168.1.2
For eg : VLAN10  192.168.10.0 255.255.255.0
I Have created L3 Vlan  192.168.10.3 at core switch 1 and 192.168.10.4 at core switch 2 and trunk link between two switches for stateful failover  among ASA ,
           I have internal 6 vlan  at core which will have default route pointing  inside interface to Active ASA , My question over here reverse route for internal network from ASA to core switches ,whether i need configure reverse route for internal network from ASA  pointing to 192.168.10.3 and weightage route to 192.168.10.4
                        Else i need to run HSRP between core switches and pointing the reverse route from ASA towards standby ip address of core switches .If my Core Switch 1 fails , stateful failover will happen and switch to  ASA 2 then then reverse route from ASA 2 will also have reverse route pointing to  HSRP standby ip address.
                           If i am wrong here please correct me over here need ur help
2 Accepted Solutions
Ganesh Hariharan
Hi All ,
Yes you are right as the internal vlan are in different subnets then you need to drop reverse route for those subnet towards the switches.If you are configuring HSRP for traffic towards internal traffic from ASA then point towards vip.
Hope to help !!
Ganesh.H
sachinraja
Level 9
Level 9
I would think HSRP VIP option will be the best & only choice here:
with option 1 - having routes to physical IP addreses of vlan 10 -> you will have two different routes on both the ASA's and unless you are running active/active, you will not have config sync between the ASA's. eg - ASA 1 will have route inside x.x.x.x x.x.x.x 192.168.10.3 (say) , and ASA B - route inside x.x.x.x x.x.x.x 192.168.10.4 .. so the route configuration mismatches between the ASA's and configurations arent synchronised (which is an issue)
with option 2 - You will have a single route pointing to HSRP VIP on both the ASA's  - route inside x.x.x.x x.x.x.x 192.168.10.5 (VIP)... this would make sure you have configurations synced between the ASA firewalls. just to note, even if you have VIP's configured, your physical path depends on which ASA is forwarding packets to !.. for eg, if ASA 1 goes down, incoming traffic hit ASA 2 - your HSRP will still have core 1 as the primary.. hence on layer 2 your ASA 2 will forward traffic to Core 2, which inturn forwards traffic to Core 1 over the trunk, and your data stream is forwarded..
Hope this helps..alll the best..
Raj
Ganesh Hariharan
Hi All ,
Hope to help !!
Ganesh.H
sachinraja
Level 9
Level 9
Raj
