IOS question
Hi group,
We are running with 3560 Catalyst switches and are looking to upgrade the IOS. Currently, we're running 12.2(35)SE5 (c3560-advipservicesk9-m). Can someone give some guideance on choosing an IOS? I do know to look for GD (general deployment), but anything wrong with jumping software release families to, say, 12.3?
Chris
Thanks for the output Chris
The only difference in Advance IP services image is that they support IPV6 Routing & Services and CEF V6.. Im attaching a pdf which has feature wise differences between these IOSs.Hope this helps.
Raj
8 Replies 8
sachinraja
Level 9
Level 9
Hi Chris
You have a lot of ED releases for 3560... You can look at 12.2 (53) SE IOS which is the latest in the train.. you might not have 12.3 on 3560's yet...
Min DRAM - 128 MB, Flash - 16 MB...
Look at the relase notes and have a look at caveats before upgrading.. make sure the open caveats dont affect your production traffic by any means.. Look at the following URL for release notes:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/release/notes/OL19708.html
Hope this helps.. all the best..
Raj
   There is no 12.3 releases on any of the 3X50 series switches , use the latest in the 12.2 train for updated security and or enhancements.  GD code is really a thing of the past . they have already indicated  that there will be no more GD code after 12.3 .
Jon Marshall
christopher_hall@earthlink.net
Hi group,
Chris
Chris
The only thing i would add to Raj's post is that if there is no reason to upgrade then personally i don't. If you are looking for new features then find the minimum release needed and then work through the caveats sections as Raj suggested.
Jon
Thanks for all the feedback!
One last question: what is the difference between the IP Services and Advanced IP Services? We are currently using the advanced ip services. What file should I use for VoIP? If it matters, we're running Shoretel voice.
Hi Chris
This is taken from the Q&A of 3560 :
"The Cisco Catalyst 3560 Series can be purchased with the IP Base or IP Services licenses pre-installed. The IP Base license (formerly called the Standard Multilayer Image, or SMI) offers advanced QoS, rate limiting, ACLs, and basic static and Routing Information Protocol (RIP) routing functions. The IP Services license (formerly called the Enhanced Multilayer Image, or EMI) provides a richer set of enterprise-class features, including advanced hardware-based IP unicast and IP Multicast routing as well as policy-based routing (PBR). Upgrade licenses are available to upgrade a switch from the IP Base license to the IP Services license"
can you get us the show version of the switch ? You are having IP services and not advance ip services right ?
Raj
SW05-3560-01#sh ver
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(35)SE
5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 20-Jul-07 01:44 by nachen
Image text-base: 0x00003000, data-base: 0x01500000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
SW05-3560-01 uptime is 5 weeks, 4 days, 11 hours, 13 minutes
System restarted at 03:48:49 EST Thu Dec 17 2009
System image file is "flash:c3560-advipservicesk9-mz.122-35.SE5/c3560-advipservi
cesk9-mz.122-35.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560-24PS (PowerPC405) processor (revision Q0) with 122880K/8184K byte
s of memory.
Processor board ID FDO1133Z749
Last reset from power-on
3 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1D:45:A2:3E:00
Motherboard assembly number     : 73-9673-09
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO1133043A
Power supply serial number      : DTN113041ST
Model revision number           : Q0
Motherboard revision number     : B0
Model number                    : WS-C3560-24PS-S
System serial number            : FDO1133Z749
Top Assembly Part Number        : 800-25861-04
Top Assembly Revision Number    : D0
Version ID                      : V06
CLEI Code Number                : COM1X00ARC
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   26     WS-C3560-24PS      12.2(35)SE5             C3560-ADVIPSERVICESK
Configuration register is 0xF
Raj
