CiscoWorks Export config compare
Jan 25th, 2010
I have LMS2.6(RME4.0.6) on Windows. How can I export the Config Diff Viewer - Compare Startup vs. Running configurations screen to a usable file (PDF, CSV, etc)? If I select the Export button in the upper right of the screen, it will only export an XML file to a directory on the server. Please advise.
Joe Clarke Mon, 01/25/2010 - 21:12
You can only export to XML.  However, you can use cwcli from the command line to do a config compare.  For example, to compare config version 1 of to the latest archived version, use the following command:
cwcli config compare -u admin -p admin -device -version 1
This will output the diff in plain text.
Related Content
