log timestamps aren't the same as system/device time
Answered Question
Jan 25th, 2010
i have a few devices, switches and routers, that when i do a "sh logg" the time stamp is different than the time the router has.
does anyone have a suggestion on how to fix this?
i pasted a quick example of what i'm talking about.
Jan 25 20:20:48.075: %SYS-5-CONFIG_I: Configured from console by grivers on vty1
Jan 25 20:22:49.659: %SYS-5-CONFIG_I: Configured from console by grivers on vty1
Jan 25 20:29:29.661: %SYS-5-CONFIG_I: Configured from console by grivers on vty1
KWCHSW27#sh cloc
14:34:10.545 Central Mon Jan 25 2010
KWCHSW27#
Thanks, Gary
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello Gary,
adding the local-time option at the end of
service timestamps log|debug datetime
can be of help
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 01/25/2010 - 12:42
  • Hall of Fame,
    Founding Member
Hello Gary,
can be of help
Hope to help
Giuseppe
tcrane8080 Mon, 01/25/2010 - 12:48
Thanks for the advice...
i tried both cmds but neither one corrected the time stamp.
i pasted an example of the output,
Jan 25 20:45:17: %SYS-5-CONFIG_I: Configured from console by grivers on vty0
6d22h: %SYS-5-CONFIG_I: Configured from console by grivers on vty0
Jan 25 20:46:13: %SYS-5-CONFIG_I: Configured from console by grivers on vty0
KWCHSW27#  sh clock
14:46:26.929 Central Mon Jan 25 2010
KWCHSW27#
it looks like the log is showing UTC.
tcrane8080 Mon, 01/25/2010 - 12:53
i re-read your reply and added "localtime" to the "service timestamps log datetime" cmd and it worked.
Thanks for your help.  Gary
